I dont care what any of the advertisements claim about fuel additives for Ehthanol gas. Its all snake oil in my opinion. I have a 1994 Yamaha Pro50 on my Boston Whaler. The boat gets used alot in spring and summer but less in autumn and winter. Ever since Ive owned the motor, Id have to take it to the mechanic every year to for some part in the fuel system to be replaced. Even though I was using Sta-bil. Two years ago, I stopped using Ehtanol and started paying more for Rec-90 gas at the locl marina. What a difference. The motor runs better. Is more reliable and hasnt been to the shop on a fuel related issue since then.
I don't care about the claims either, but you are wrong about the "all snake oil claim." it is very unfair to the companies that make effective treatments. I have run independent testing programs, both laboratory (ASTM methods) and field, and those I mentioned are VERY effective at stopping corrosion.
By the way, Sta-bil is not one of the ones I mentioned as being "very effective." Sorry about that.
1. I run 3 outboards (twin engines + dinghy). No clogging in the last 5 years, since I started with good additives. Before that... lots. THAT is why I got into marine writing; I researched the problem and solved it.
2. I have never sought out ethanol free gas. With the right additive, there is no need. And make sure you close the vent. I use a silica gel vent filter on the main tank.
3. I opened up my 5-year old carbs this fall, just to see. The old carbs had pitted, but the new ones were factory shiny.
So pay silly prices for non-e10 if you must, but you don't need to. Just do all you can to keep it dry, and treat it to cover the trace you miss. I don't like ethanol, as a matter of politics, but you can live with it, if you learn the "ethanol rules." You might as well, since it is still on the rise.
