My 1990 C-22 came with a factory Ideal trailer , single axle. Never had a problem ("issue"
with the weight. And I wouldnt worry too much about the brakes....I doubt the hydraulic surge brakes on mine worked half of the time.....couldnt tell the difference. I vote for the later boat.....many improvements .. Unless you are a hard core C-22 racer.
Hey Doug,
No, not a hardcore racer. But it would be nice to have a 150%, and even a cruising chute, for normal use.
As for the brakes, I need them to be legal for the trip home, so I can't just install them when I get back.
My dodge ram curb weight is 4,060lbs boat and trailer 3,300
Regulations in this state/province say brakes are mandatory if the trailer is "over 2,000lbs AND more than 50% of the tow vehicle weight".
No worries really, I would be installing them anyhow.
As for the axle, I figure I'll wait until I've hauled it home.
I plan on hauling the boat on some rough gravel roads to remote lakes. Besides the better handling that you get from tandem axles, it's much safer if you get a blowout. Not a good thing on a 1.5 lane remote gravel road. Tandem should also help on bad launch ramps. There are some here that are more like rubble piles that concrete.
Initally I may keep the single axle. I don't plan on taking the boat in the more remote locations until I've sailed her a bit.
I plan on looking at the local insurance auctions. Sometimes a trailer will sell for close to scrap value. I could use the running gear on the boat trailer, and use the rest of the steel of a project.
I just got off the phone with the seller of the 78 C-22.
-Owner is moving up to a C&C.
-It DOES have a pop top.
-The complete keel system was redone on it. Cable, ball, pin and bushings etc.
-The trailer hasn't been used much. It got hauled 500 miles after brakes and bearings were overhauled, then maybe 60 miles since, with bearings repacked as needed. He said it needs a paint job but it's strongly built. Tires are only a few years old.
-The main is about 5 years old, the others are older, but in good shape.. The 100% he described as "usable". He races the boat but not hardcore.
-in addition to what the ad says, he got a new sliding hatch from direct from catalina.
-interior lights are working fine. Has 12 volt battery.
-no depth finder or electronics on board.
-they sailed the boat about 50 times last year.
-Boat originally from the B.C. Coast, but last few owners have all been freshwater.
In all it sounds like a decent enough boat.
But I'm leaning 99% towards the later model now.
Looking at the detailed list of differences between the mk1 new style and original, and the nice low design of the trailer that the seller has for it has convinced me it's a better deal.
I can always add a trailer axle, brakes or more sails, but adding an anchor locker or eliminating wood used as hull stiffeners is not an option.
I've told the seller that I'll take it, as long as the survey doesn't find anything and the Admiral has had her chance to pass judgement.
