THats pretty cool. I would like to go cruising in that thing for sure. I wonder if anyone has anyone has ever attempted to make a sailboat with horizontal sails like wings?
howard Hughes old boat?
http://inhabitat.com/the-cosmic-muffin-a-boat-recycled-from-howard-hughes-plane/
IIRC,
a few years ago allied roofing stuck a metro bus on a barge with an outboard. can't find any pictures. but I anchored next to them at the air and sea show... 4 sofa's inside and shag rug... it looked strange too. think they do the boat parade.
Todays projects:
1. Learn how to use duraglass, fill holes.
2. Sand a bunch of epoxy and fiberglass
3. Mix up some lay-up poly resin and laminate new ply into deck
4. Epoxy ply and glass into deck by forestay. Changing to a deck mounted head stay instead of Mac. chain plate that went to hull.
5. Glass over old cockpit drain/cable hole. I will be putting in a smaller brass tube in the same area. Have to figure out the bolt that is there to take the rubbing from the winch cable. Maybe a sleeve of metal?
6. Glass over ply laminated into deck
7. Fix two cracks on side of deck from flexing with glass
8. Sand CB for coat 2
9. Grind out/remove old quarter berth stringers. New ones in more outboard position on the way.
10. Remove rotton ply that was laminated into transom to reinforce motor mount.
11. Cut 3/8 marine ply into shape of entire transom.
12. Warping that ply under CB to get correct bend.
13. Drink beer and relax.
