Hunter H22 Spreader Bracket Replacement
Jul 5, 2021
8
Hunter H22 Brainerd, MN
Hi, all. I'm replacing a broken spreader bracket on my Hunter H22. I have the new bracket in place but holes do not line up for me to rivet. I'm concerned that if I drill new holes in the mast I'll weaken the mast, but I'm not sure what other options I have. Can I simply drill new holes a short distance higher on the mast and rivet the bracket in place in place or do I need to also have the current unusable holes welded shut? TIA.
probably safe to just drill and rivet but if you want to be extra cautious, you could fill them with JB Weld. (Easy Peasy)
Likes: philiefay
