Hi fellow sailors,
This forum is absolutely amazing. And special thanks to @stickinthemud57 for great introduction and long and detailed emails. Hopefully, we can continue that here as I make progress.
Here's my story and I open this post with ask for support and advise from experienced people, so I get this project through and get on the water again. So also, I apologize in advance for lacking some proper terms, as I'm still learning the vocabulary.
I am new to sailing as I only owned Laser 2 for a few months and went out with it only several times at Canyon Lake, Texas and had absolute blast. I fell in love with the feeling being powered by wind.
I was fortunate that I was gifted a project Hunter 170 boat from a very generous person, that started the work on this boat, but it is kinda in the middle when I got it. After I got the boat, I sold my Laser 2 and from the money, I ordered new sails for this Hunter 170 from Precision Sails and I already receive them.
- He built enclosed section in the front that replaces the tarp section on the original design. The plywood is covered with three layers of fibergrass and the front has been varnished. I'm planing to sand the edges, do some fairing and paint white, then place non skid on top.
- Cracks. Lots of them. The previous owner already filled in lots of cracks using Plexus and sanded some of them, so most is ready for putting primer on and paint with Krylon Paint White and Clear Gloss on top of it. I see only two small cracks that I need to fill in, so I'm going to use Dremel tool to create a V shape groove and fill it with Plexus, and then sand it flush.
- Hull Hatches for inspection/access holes. Here where I want to build the hatches. on the rudder, for rudder work. I've seen that done from other people here, so I guess it's ok. Then for the motor, I want to use Minn Kota trolling motor and for it I need battery power. I want to put the battery (in waterproof casing) under that wooden enclosing in the front, then have a hatch to the right of that, have an waterproof connection for the power line, then put and glue pvc pipe under the starboard bench and have another hatch opening and connection for the marine wire (that will go through the pvc). Once I build the motor mount the motor will be right there and the cable will just connect to the connector next to the hatch.
Please, let me know if that idea could work and if opening those hatches will not hurt the structural integrity of the hull?
- Motor mount. I'm looking at the option to have someone to weld for me stainless steel L-bracket 6"x4"x3" (LWH), but I'm not sure if it will come up too expensive. I see people mount those Minn Kota motors on kayaks, so I wonder if I can build it with plywood pieces covered in carbon fiber and screw it on the mount location. Do you think that would be strong enough? I kinda think it would be fine. I only want to have that motor to slowly push me away from the lake ramps a bit in a deeper water, so I can then slowly work on the sails.
