That's a lot of cycle time. How much does it draw while running? My 12V fridge will cycle on for about 5 to 10 minutes once every couple hours in moderate temperatures, maybe once an hour or a bit less in the tropics. Depending, of course, upon how frequently the door is opened. It draws something like 6 to 8 amps while running.How often does your fridge cycle and how long will it stay cold if it’s not run? My 12V fridge cycles about 10 minutes on / 10 minutes off in moderate temperatures. It could probably stay cold longer than 10 minutes but I presume the designers programmed it that way for efficiency or some reason like that.
If I had a choice I’d rather have a 12V fridge that runs whenever it needs to than a 120V fridge that only runs when I don’t mind the noise and fuel consumption of a generator.
dj
