I am thinking about buying a sailboat that is stored on a lift, and the way it’s been stored, without support under the keel, is giving me second thoughts. The boat has been setting there for about two years unused, with the mast up, and as far as I know the present owner has been storing it that way for maybe six years (when it wasn’t in the water).
The boat is solid fiberglass, has a draft of 4’, 1800 lb. of ballast, and displaces about 3800 lb. The keel is bolted on.
Do you think the keel to hull joint could crack once it is blocked properly? I’m just wondering what the worst case scenario could be.
Has anyone seen damage caused by this type of storage?
