Here's some electrical upgrades I did last summer, finally got around to taking some pictures of what I ended up doing. The electrical setup when I purchased the boat was abysmal at best and I knew I was going to be power hungry after adding everything I wanted to the system.
1988 Catalina 22 Wing Keel (New Design)
I wanted to repurpose the battery compartment in the cockpit that had the single battery (group 24) and I also wanted to get more weight forward so I used the compartment under the v berth to house the new battery bank (2 gel Group 27 batteries) These Gel batteries are great and there is no concern for gassing or problems with a heeling boat. Each is 100AH giving me 200AH of available storage.
I used the storage compartment in front of the porta potty to mount My inverter (inside), Battery charger (inside), battery disconnect (outside), Solar charge controller (outside), WRGFCI outlet (outside, comes off the inverter when powered on), Inverter on/off switch (outside) and 6 circuit dc switch with battery monitor (outside). The lid lifts up and reveals everything inside. I mounted the charger on the underside of the lid, and the inverter (1000W) in the bottom.
I reused the existing Catalina dc distribution panel to keep the cabin lights and running lights etc but put all new loads on the new 6 circuit panel. (Autopilot, VHF, Garmin chartplotter, Fridge,) I have 2 spots remaining.
The fridge is the best one I could find that fit in the space I wanted to use. It draws 5 amps at 12v dc and has separate fridge/freezer temperature settings. If you remove the divider it becomes a bigger fridge or freezer with one temp control. It was rated to function at heeling degrees so that was a big feature I looked for. A lot of these fridge coolers need to be level to function.
