As part of spring commissioning, I want to extract 1 cup of diesel from the bottom of my tank to check for water or sediment. I'm curious what method(s) others have used to do this that I might replicate? Thanks in advance!
I have a manual fuel pump. Where would be the best place to insert the hose?Think straw.
I've never found a trace of bacteria in the fuel simply by adding a shot of Biobor JF with every fillup :
If your using Biobor and replace your fuel maybe every year or so, your fuel should be clean enough to drink .Thanks! I use Biobor also.
