I have a Mastervolt Whisper 8 generator With a Mitsubishi L2E engine. It usually starts slowly before rumbling to life. After that, it runs smooth and strong. Sometimes, it does not start on the first attempt. The control panel automatically goes through the start sequence again with he fuel pump priming and the glow plugs glowing before start attempt number 2. On the second attempt, the entire fires right up. The same battery set up fires the Yanmar 110 HP auxiliary engine up immediately so I know it's not the batteries. I had the starter motor and solenoid checked out, and they are fine. I also tried starting without the sound shield just in case it lacked air. What should I check next? I am assuming that the generator should start immediately like the Yanmar.
