Has anyone here accidentally capsized an H170? And if so, how did it happen?
Reason I ask, is I've heard---somewhere--about the boat being "tender" with large sail area, light weight, high position of main, possibly hull shape... But I've found it actually seems realatively hard to do.
I've had my H170 only about a year and a half, but I sail it most every weekend all year long, usually by myself, in a variety of wind conditions. In high winds (usually 25kt predicted) I've sailed with main only, reefed main, and both sails. Generally, when the boat leans more than about 45 degrees, with main only, it heads up into the wind (as expected). This past weekend, with 25-35kt gusts, sailed mostly with both sails (flattened main), and I had a hard time keeping it from heading up in large gusts (close reach). I thought the jib out would keep it in line, but there still is a point when the water hits the top of the hull, that it still turned into the wind. I suppose the rudder is comming out and the boat pivots. Once, the boat was leaning quite a bit, but I wanted to avod a bit of crud in the water, and tryed to do a quick serpantine on the downwind side, but pulled the tiller and it still just went straight, slowing with the drag.
And I hesitate to mention the one time I had an accidental gybe on a weird day, just pulling away from the dock--me scrambling not to fall in backwards, boat starts leaning, turned into the wind, and settled before I got it together. Embarrassing. Is it hard to tip this boat over?
