Best place for a fire port?
danb2k
Apr 20, 2015
15
Catalina 36 Mk II Salem, MA
Hi All,
I want to install a fire port on the wooden engine cover in my 2003 Catalina 36. I'm looking for placement advice: would it be better on the top of the cover, behind the companionway steps? (For this, I'd have to cut through the formica too). Or would it be better on the face of the cover, directly behind a lower step? Thanks for your input.
Apr 12, 2007
177
Hunter 420 Herrington Harbor South
Just off the top of my head I would not put it on the top. If you have a fire the heat will go up right into your fire port. Might get a little toasty trying to put an extinguisher into the hole. I have had 3 different boats, and each fire port was on the side.
Likes: danb2k
Jan 4, 2006
6,497
Same as for Hunter. Low down for a cooler location and out in the open for easy access.
