Are golf cart batteries better than marine batteries
Apr 8, 2010
1,956
do you keep the emergency battery all wired and charging? do you controller with the main battery 1, 2 , switch? thanks
We just Keep It Simple, and use the factory 1-2-all master switch. The house bank of the two big GC batteries is on position 1. Position 2 is the "emergency" battery choice.
What with a well insulated 12 volt refer box from the factory, and all-LED lighting, we can easily anchor out for two days (plus) and never exceed the useable capacity of the house bank. The house bank is rated at 260 AH, which effectively gives us about half that without harming the batteries. The longest time we have obtained out of this bank was 9 years before having to replace them; and they have always lasted at least 5 years.
Remember that the small diesels on boat like ours almost never need enough power to justify a separate "starting battery" like a much larger boat might need.
We do have a solid state multi stage shore power charger. Also, a Balmar Smartgauge to give an instant readout of % of capacity and voltage. I have maintained the redundancy of the factory expanded-scale analog volt meter as well. It's great to have (reasonably) fool proof methods of checking voltages.
And, in a nod to the requirements of insurance and the ABYC, we have two large-amp breakers adjacent to each battery pos. terminal, "just in case".... :cool:
Likes: Tally Ho
Apr 8, 2010
1,956
Specify the ELPT post to keep the height to a minimum, and to satisfy the requirement for marine use.
interesting, do you remember how tall the 6 V batteries were?
Yes…I just checked. That info is available on post #2 of this thread. The Trojan tech page link to GC batteries answers this pressing problem.
JRT
Feb 14, 2017
2,048
The easiest way to figure out height is to measure you area max first then goto either Battrries plus, NAPA or Sam's a d ask to measure a 6v GC height. You also need extra battery cables to connect the 2 6V together to make it a 12v, so that is a make or buy addition too.
NYSail
Jan 6, 2006
3,069
Beneteau 423 Mt. Sinai, NY
Relative to the Golf Cart market, the marine market is minuscule. Not worth the marketing effort and expense. The same companies who make GC batteries also make 12v Marine Batteries which West Marine sells at inflated prices to naive boaters. It is at once capitalism at its best and worst. If I were in the market for GC batteries I would look to source them from a dealer who dealt with large volumes of GC batteries, the batteries would be fresher and cheaper than a GC battery with a Marine label. That's good consumerism.
Experienced sailors learn from their experience and from listening to those who are experts in their field, like Nigel Calder, Rod Collins, the folks at Panbo, Steve D'Antonio and others. From them, we have learned the pros and cons of various battery chemistries and forms, how to safely install an optimize our systems, and myriad other bits of information which make our sailing and cruising experiences safer and more pleasurable, Thanks guys!
could not have been said better….
Likes: Maine Sail
