Hi, I am new to the forum. I am the proud owner of a very used Bombardier 4.8. I have a few questions which I have been having difficulty finding answers to.
First, I am all at sea (pun intended) as to how the centerboard is supposed to be rigged. The owner's manual I have is no help; it may possibly have made sense if the brand-new boat with all its original equipment was sitting there in front of you, but alas, such is not the case. The board has a hole in it which is, I assume, for an uphaul/downhaul line; but if I put a line through it, then I can't lower the board past about a 45 degree angle, whereas it should swing all the way down perpendicular to the waterline.
Secondly, I don't know how to rig the roller furling on the jib. There are no fairleads or cleats for the controlling line. It seems like a block and cleat arrangement of some sort must be missing.
Finally, I would like to find technical specifications for the boat and its hardware. Especially, I want to find the specs for the centerboard and rudder. The blade of the rudder that came with the boat - which was not the original - broke off and floated away last time I went out (the wood under the fiberglass coating rotted out) ... I based my new one on guesstimated dimensions from the remains of the old rudder head and a profile drawing I found, but I'd like to know the actual design dimensions.
