I bought a Webasto self contained unit and can't find an easy place to put it in. I read the Mainsheet article and the port locker seems like a less than ideal location only because i have to open/cut a hole for the return grille. I'm thinking about under the v-berth but running the ducts seems nearly impossible from there towards aft of the boat. Also, where do you place the return grille? I need a 14x10 and can't find a place for that big of a hole. Another option is on top of the waste tank... any suggestions? Where would the return be if I install it aft? What about starboard side? If anyone can share pics of their setup I'm sure I can work on it.
