Raising the Hood furler drum to fix stiffness
Another writer says that he raised his drum to fix his stiff furler. What he is referring to is to reposition the hocky puck disk at the base of the drum. To see the disk, fix a jib halyard to the drum where you would normally conect the sail, hoist tight, and now look under drum just above forestay attachment at bow. You will see the black disk, which has two screws that can be loosed, disk moved up the forestay a bit and retightened. . This may cure your problem.. or maybe the disk has broken and needs replacement. the disk is just a large surface plate to hold the drum up off of forestay attachment. It is no really a bearing surface, so don't expect the drum to free spin on the disk. The drum rests on the disk and the drum has 2 sets of bearings (zillions of little balls.. like in a bicycle bearing). If the disk is okay, then look to the bearings and call Hood.
