- Oct 22, 2014
- 21,196
That sounds eerily familiar. I think in my case the engine is tight and needs some hours of run time. But I’m also going to try and adjust the timing a wee bit. Thinking the hi pressure pump is a hair advanced putting too much fuel into the injectors/cylinders so I’m not getting full combustion at the start. Once running it may be a bit rich but that appears to be ok. I’ve not yet enough time to check fuel consumption. I’m not yet ready to try and put an exhaust sensor into the pipe to measure the exhaust.
