Hatch leak repair
Tom TH
Nov 22, 2023
2
O'day 222 Punta Gorda - Charlotte Harbor
The forward Hatch on our O'day 222 leaks during rain events.
Is there a way to remove only the cover so that I can get at the top edge to clean and recaulk the perimeter where it it meets the deck?
Right now I can access the sides and lower edges, but the leak probably originates at the top edge.
I don't really want to remove the entire hatch for rebedding unless there is no way to detach the top from the bottom frame.
Thanks for the help.
Tom Heiting
Jun 21, 2004
2,534
Beneteau 343 Slidell, LA
[QUOTE="Tom TH, post: 1806291, member: 163741
[/QUOTE]
Can you supply us with info regarding the manufacturer of the hatch?
dmax
Jul 29, 2018
993
O'Day 35 Buzzards Bay
If your hatch is like mine (it looks like it is from images of O'Day 222), the answer is no - you need to remove the frame to rebed. Here's what mine looks like:
Jun 21, 2004
2,534
If it is a Lewmar hatch, yes the lid can be removed. There are two plastic covers that need to be removed at the hinges. There are two threaded barrel hinges that need to be loosened. Refer to Lewmar instruction on their website for specific instructions.
dmax
Jul 29, 2018
993
Yes but that's not going to fix the leak - you can't seal it from the outside.
Tom Heiting
Once the hatch starts to leak from the deck/hatch joint, the only cure is remove the hatch, clean and rebed. It sounds harder than it is. If the hatch is leaking at the seal between the frame and lid, then it may not be necessary, but may be easier to remove the lid and replace the gasket.
Jun 21, 2004
2,534
Depends on where the leak is. Could be the rubber lens seal/gasket, gasket at handles. Of course, if the base is the source of the leak, it will require complete removal & rebedding. Recently repaired one of my Lewmars by removing lid only & replacing rubber lens seal, hinge seal, & handle gasket; did not have to rebed the base.
Lewmar hatches are somewhat notorious for leaking hinge seals.
Likes: BigEasy
dmax
Jul 29, 2018
993
From this:
Is there a way to remove only the cover so that I can get at the top edge to clean and recaulk the perimeter where it it meets the deck? "
I was assuming it was the base that was leaking but maybe it's in the seals. Any O'Day hatch that hasn't been rebedded at this point is leaking at the base, guaranteed :)
Tom TH
Nov 22, 2023
2
Thanks to all for the advice.
Looks like hatch removal is the way to go.
Jan 7, 2011
4,838
Oday 322 East Chicago, IN
I pulled one of mine (O’Day 322) to rebed it…interesting laminate.
That's pretty typical. The blue stuff is probably Interlux Watertite fairing compound. It serves 2 purposes to close up the gap between the deck and the headliner so water can't get between them and to add some firmness to the deck around the hatch. Similar to the hatch opening in my quarter berth.
Jan 7, 2011
4,838
Interesting Dave…I assumed that there was some sort of foam board in the laminate (at least around the hatches).
Next time I pull one of the hatches, I will probe around a bit more.
Another technique some builders used was to put gobs of polyester putty on the headliner before the deck was lowered. This glued the headliner to the deck. Gobs is a very precise quantity. :biggrin:
