Yanmar Zincs
Don Connolly
On my Yanmar 2GM there are two zincs, one on the Stbd. side and one on the rear of the engine. In the process of replacing them I can get the rear one off, but cannot remove the Stbd. side one. Have removed everthing from the engine to give access but still haven't room enough to give leverage to break it loose. Any ideas? Also since I have replaced one of the zincs can I let it go at that. Thanks
Don Alexander
Zincs - Yanmar
Don, I owned a Yanmar 2GM for 18 years and though I took the zincs out regularly I never needed to replace either of them. Your installation may be different and the water will not be the same in your area. The one on the rear only responded to a hammer blow on the end of the spanner. Regards, Don Alexander
