G
Grandpay@aol.com
I have followed the thread about the "cold start", No fuel problem on the C320's. I have tried working with my local service facility with no luck. They claim they cannot get a service kit from Yanmar. If you aren't familiar with the problem it goes like this, engine fires right up then dies as if running out of fuel. After bleeding or pumping the throttle, if you are lucky, it will start again and keep on running. If you shut it off and let it sit for a few hours it will also start right up but if you let it sit overnight or longer you go through the whole process again. The alleged fix is to the fuel line that allows fuel to drain back to tank???? I need help. Possibly a fix I can do myself because I have had a repair order in for over a year.
