Now picking up "Good Vibrations" .....
Well folks,Hauled out two weeks ago, and had one of those rare moments I thought I'd never see .... my Y-30 coming out, and there on the hard was another y-30 that went back in about 3 hours later! (Brian & ... Linda?, boat named "Indecision")Anyway, during the haulout, I stripped the VC Offshore, stripped and recovered the keel with "Blue Steel" and then recovered all with Micron CSC. There had been some amazing growth primarily on the steel part of the keel (like about half or the Vancouver aquarium) so I tried my best to give it a proper sealing. I just had a chance to overnight Sat/Sun and can tell you that she goes a tad quicker now!BUT ..... The best part was during the haulout having the steady bearing close to the engine replaced and adding another steady bearing close to the dripless seal so that the shaft is now well supported. (Thank you Keith from Gartside Marine!) What a difference to the noise level and vibrations! Still like to find the sweet spots in terms of rpm but now can listen to the radio while motoring, which was virtually impossible before. Even with the companionway open, at the right rpm the loudest thing was the exhaust sputtering.Now if only this darn work thing didn't get in the way of my sailing time!cheers all,Craig
