Working on interior wood
2
Catalina 30 Mt. Pleasant, SC
I am looking to revarnish some interior wood on my 1995 Cat 30. Can anyone recommend a varnish that will match the factory coat because I am only looking to do high traffic and worn out areas such as the steps and some trim in the galley. Also please correct me if it is not a varnish that is on the wood out of the factory. Thank You.
May 25, 2004
173
Oday 25 Tampa Bay
Someone will have a stroke when I tell you this,
but I used the left over "slikkens {spelling?] cetol" on the interior and it looks fine to me. Cetol is the same stuff that has been used on the exterior teak and it looks great and has protected the wood. One hint thou, put it on VERY lightly, if you use too much at once it won't look good. You MUST do several coats LIGHTLY! Good luck, Jack
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Interior Wood
Call Catalina, they can tell you the exact type and brand of the original finish: 818-884-7700.
