Winterizing the Mermaid
Pat
Jun 7, 2004
1,250
We have a 12,000 btu Mermaid AC in our O'Day 272. Prior to this I have had our club
Property Manager winterize the AC....so far it has always happened when I was not there to see
how he did it.....This winter I've asked Santa for an air compressor (portable 110 v) that I can use to blow out the lines in the AC....The boat is currently on a cradle but I have power and can use a
110 air compressor w/ the correct fitting and blow out the hoses, compressor, etc.....I also could winterize it I suppose w/antifreeze. Here is my simple question; which way do you winterize your AC? Air compressor blowing out lines or turn it on and suck antifreeze thru it?
Thank you for your always helpful advice. 'Patrick on the Plains'
7,437
Alden 50 Sarasota, Florida
Some people blow out the lines. Others run antifreeze through. Both methods will work. If you do the former, drain the pump as air won't move any water contained.
Pat
Jun 7, 2004
1,250
Thank you Don for your guidance....I never thought about the air compressor not blowing the water out of the pump...
good advice....I've had to replace the glass bowl of the filter several times...that may be why...Patrick
