If you have a raw water cooled engine it might be useful. This is the type of engine where the sea water is pumped directly through the engine block to cool the engine. If you engine is fresh water cooled where you use an antifreeze mix in the engine then the engine is operating just like a car engine and you just need to change your antifreeze at the engine manufacturers recommended interval. Since you didn't provide info on what engine is installed we can't really answer your question.
