Ron Dague
There was some discussion about using a small pump in the fuel line to make bleeding the lines easier. Some writers used manual bulbs. Here's my experience:I had a small, diesel compatible, electric fuel pump, in the fuel line, before the Racor filter. It does make bleeding the line easier. But, while sailing yesterday, it began to leak from one of the seals. By the time I found the problem, removed the pump, and re-connected the line, 1/2 gallon of diesel fuel was in my enging bilge. Fortunately, I keep the plug in, so it didn't drain into the main bilge. So, a fun afternoon of pumping the bilge fuel into a bottle, wiping up the rest, and then removing the pump from the line.Here's the lesson that I learned (and I'm not trying to tell anyone else what to do, just my decision): Having removed that pump, I won't replace it. Every additional mechanical device put in the fuel line is one more part to break or leak, when you least expect or need it. And although careful visual inspection is valuble, it isn't foolproof. By using just the lift pump on the engine, if I have a problem, it will most likely be at the dock when changing filters, not at sea. If it takes me a little longer to put in new fuel filters and bleed the lines, I'm willing to trade that time, for a less complex and less likely to break, fuel system, when under way.Just my humble opinion.
