I shall try to cut and paste a catalog page
View catalog pages (6) Belts1174 products match your selections Type Timing Belts Trade Size Select Trade Size: 28MXL 32MXL 36MXL 40MXL 44MXL 48MXL 50XL 52MXL 56MXL 60MXL 60XL 64MXL 68MXL 70XL 72MXL 76MXL 80MXL 80XL 82MXL 88MXL 90MXL 90XL 91MXL 96MXL 96XL 100MXL 100XL 104MXL 108MXL 110XL 112MXL 115MXL 120MXL 120XL 124L 124MXL 128MXL 130XL 132MXL 135L 136MXL 140MXL 140XL 144MXL 150L 150XL 152MXL 160MXL 160XL 165H 165L 168MXL 168XL 170XL 172MXL 175H 175L 176MXL 176XL 180MXL 180XL 187L 188MXL 190XL 192MXL 195L 200MXL 200XL 202L 208MXL 210H 210L 210XL 212MXL 217L 220H 220XL 224MXL 225H 225L 230H 230XL 236MXL 240H 240L 240MXL 240XL 248-8M 250XL 255L 256MXL 260XL 270H 270L 270XL 280XL 285L 288-8M 290XL 300H 300L 300XL 304MXL 310XL 315L 320H 320MXL 322L 330H 330XL 340H 340XL 345L 350-5M 350H 350XL 352-8M 360H 360XL 367L 370H 370XL 375-5M 380XL 386MXL 390H 390L 390XL 400-5M 400H 400XL 405L 410H 416-8M 420H 420L 420XL 425-5M 450-5M 450H 450L 450XL 456-8M 460XL 475-5M 480-8M 480H 480L 480XL 490H 500-5M 500XL 510H 510L 535-5M 540H 540L 544-8M 560-8M 560H 565-5M 570H 570XL 585H 600-5M 600-8M 600H 600L 608-8M 630H 630XL 635-5M 640-8M 645H 660H 660L 670-5M 700H 710-5M 720-8M 730H 740-5M 750H 770MXL 770XL 780H 800-5M 800-8M 800H 817L 850-5M 880-8M 890-5M 896-8M 900L 950-5M 960-8M 966-14M 994-14M 1000-5M 1000-8M 1040-8M 1050-5M 1120-14M 1120-8M 1125-5M 1190-14M 1195-5M 1200-8M 1260-14M 1270-5M 1280-8M 1400-14M 1420-5M 1440-8M 1568-14M 1595-5M 1600-8M 1610-14M 1690-5M 1750-14M 1760-8M 1778-14M 1790-5M 1792-8M 1800-8M 1890-14M 1895-5M 1960-14M 2000-5M 2000-8M 2100-14M 2240-14M 2240-8M 2310-14M 2380-14M 2400-8M 2450-14M 2520-14M 2520-8M 2590-14M 2600-8M 2660-14M 2800-14M 2800-8M 2840-8M 3048-8M 3136-14M 3150-14M 3200-8M 3280-8M 3304-14M 3360-14M 3500-14M 3600-8M 3850-14M 3920-14M 4000-8M 4326-14M 4400-8M 4410-14M 4480-8M 4578-14M 4956-14M 5320-14M 5740-14M 6160-14M 6860-14M B-994 B-1120 B-1190 B-1260 B-1400 B-1568 B-1750 B-1960 B-2100 B-2240 B-2380 B-2520 B-2660 B-2800 G-994 G-1120 G-1190 G-1260 G-1400 G-1568 G-1750 G-1960 G-2100 G-2240 G-2380 G-2520 G-2660 G-2800 W-640 W-720 W-800 W-896 W-1000 W-1120 W-1200 W-1280 W-1440 W-1600 W-1792 W-2000 W-2240 W-2400 Y-640 Y-720 Y-800 Y-896 Y-1000 Y-1120 Y-1200 Y-1280 Y-1440 Y-1600 Y-1792 Y-2000 Y-2240 Y-2400 Form Form refers to the appearance of the overall belt. Endless belts refer to closed loops. Open-ended belting are lengths of belt that may be connected. Adjustable-length belting may be assembled to variety of lengths. Endless Belts | Open-Ended Belting Timing Belt Series A timing belt series is an industry standard designation that includes belts for a given set of width, pitches, and tooth style. AT10 Series | B Series | G Series | H Series | HPPD Series | HTD Series | L Series | MXL Series | Poly Chain GT Series | Power Grip GT Series | W Series | XL Series | Y Series Belt Construction Single-Sided with Trapezoidal Teeth: Trapezoidal tooth design eliminates the slippage associated with V-belts, and the noise and lubrication problems of metal roller chain. Single-Sided with Curved Teeth: The curved tooth profile results in more surface area contact between these belts and pulleys, providing higher torque capacity, a stronger grip, and quieter operation. Interchangeable with HTD (high torque drive), Power Grip GT, and HPPD (high performance power drive) synchronous drive belts and pulleys. Double-Sided with Trapezoidal Teeth: Double-sided for simulateous use on two or more shafts. Trapezoidal teeth mate with grooves in timing belt pulleys for a positive grip. Either side can transmit a full load; serpentine them to transfer full power on both sides. Single-Sided with Tire Track Teeth: Here's an extremely quiet belt and pulley system for your high-torque, high-precision operations. The unique tire-track tooth profile of the belts (also known as the eagle design) results in optimum surface area contact with the pulley for ver low noise and superb grip. The tire-track design also makes the belts self-tracking, so there's no need for flanges on the pulleys--this gives you a drive that takes up less space, weighs less, and puts less load on your bearings. Double-Sided Flexi-Timing: The special tooth-design of these flexible synchronizing belts allows slight to significant misalignment between multiple pulleys in a drive. Belts are double-sided, so they can be serpentined. Material RubberThe industry standard for belt materials. Durable, flexible, and is able to absorb heat that is produced as the belt moves through the pulley. Silicone RubberStand up to high temperatures, corrosion, and chemical contact. Molded PolyurethaneOffers resistance to tearing and abrasion, as well as good resistance to oils, water, and chemicals. UrethaneWill not mark surfaces the way that other materials do. Run more quietly than comparable rubber belts, while providing the same durability and flexibility. High resistance to abrasion, oil, and chemicals. Designed for light-duty power transmission applications. Belt Width 1/8" | 3/16" | .20" | .22" | 1/4" | 5/16" | 3/8" | 1/2" | 3/4" | 1" | 1-1/2" | 2" | 12 mm | 15 mm | 16 mm | 20 mm | 21 mm | 25 mm | 30 mm | 32 mm | 35 mm | 36 mm | 37 mm | 40 mm | 50 mm | 52.5 mm | 55 mm Pitch The pitch of a timing belt is the distance between the center of the crown of one tooth and the center of the crown of the tooth next to it. .08" | .157" | .2" | .375" | .5" | 5 mm | 8 mm | 10 mm | 14 mm Color Black | Off-White | Translucent Yellow http://www.mcmaster.com/I added a link but this page gives a small picture of what is available.
