Where is the water tank on a Seafarer 26? I've looked all over and I can't find it but there is a sink and faucet so it must be somewhere. ((????))
Thanks
Thanks
jhnewsome:
I guess the tank has been removed? There is nothing under the Vee berth. Are these water tanks built in or a removable unit?
Thanks for your reply.
Thanks,Mine is dead center in the V-birth and is a poly removable tank. There is a spot just to the port side of it for a holding tank if you have an installed head.
Dan
Kim - my husband just made me 3 replacement hatch boards for a 26. They work great. When i bought the boat someone had two pieces of warped plywood in there.Kim Gilbertson said:Thanks,
I think that the water tank has been removed.
on another point, since you have been so kind to answer, have you ever seen a companion way hatch made in four sections? My boat has this and it's purpose, as far as I know, is to have three of them stacked on the fourth so that there is a larger opening. I boat has a bimini top that gives standing headroom over the opening. I don't see how these sections move though.
