Where can you buy plastic sheaves for a 321?
522
Jeanneau 389 Grosse Pointe Farms, MI
Anyone know where you can buy plastic (delrin) sheaves for spinnaker and topping lift on a B321?
These are 17 mm in diameter with a 10 mm hole.
Width is 15 mm.
After taking the mast down, it was clear these are pretty worn after 14 years of use.
Tried a number of places. Next stop for me is Charleston Spar...
May 25, 2006
25
Beneteau 42 Tampa Bay Area
Width is 15 mm.
Rig-Rite can sell you the sheaves you need although a wiser choice might be the aluminum sheaves available through Garhaurer. In either case, Google's your friend.
Bosman
Oct 24, 2010
346
Solina 27 Wabamun, Alberta
I have seen many sheaves in my life, but never such a small ones (10mm axle with 17mm OD). Are you certain the dimensions are correct? OD in particular.
Jul 8, 2005
522
Yes, indeed. Took them out myself.
One from the top of the spinnaker halyard was worn to the pin since it must have got jammed. There were two at the same location so I just switched them, but thought I should also get a replacement ready.
