I'm hooking up my trolling motor with a quick connect plug. The recommendation is to install an in line fuse. My question is what size? The motor is a Minn Kota endura Max with 55lb of thrust. The web site says it can draw up to 50amp. Should I get a 50 amp fuse or a 60? My thought is to stay simple and regardless of the size just wire in an AGU holder making sure it has the same 8 gauge wire as what I am using. I will also put the tubing you heat up over all connections. Am I on track or out in space somewhere?
Thanks in advance for the education.
