Very Odd
The system you describe makes very little sense. All of the water pumps I've seen have pressure switches incorporated as part of their design. Yours does not sound like a fun system. It sounds to me as if this not the orriginal pump and aomeone just slapped in whatever was at hand. If you can support a 33 foot boat, I would think you could pop for a new pump at about $125 on sale, which they usualy are. Installation is not that big a deal.As far as the accumulator tank goes, check any house that draws water from a well, and you'll find an accumulator tank. They reduce the frequency of pump cycling. I had a Jabsco tank on my 33 that did work for a while, but it was really just too small to be much use, and it broke itself anyway. (England has never been noted for it's fine plastics!) I'm in the process of fabricating one now. It's 4" PVC pipe about 20 inches long, capped at both ends with a hose barb fitting at the bottom. It will be mounted behind a drawer inside the head vanity in an otherwise unusable space, completely out of the way. If I get energetic I'll post photos of this and other items in the Photo Forum.
