Water leak
2
Beneteau 323oceanis Frederikssund
We have a leak of water from the cold water system at the back - has anybody the same experience and suggestions for hos to fix it lur bosat is a beneteau 323
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
Where is the leak? Back of the boat near the cockpit shower? IF so, have you checked the connection at the shower head with the water pressure on?
Tejas
Dec 15, 2010
164
Beneteau First 36.7 Lake Travis
On our 36.7, a freeze cracked a fitting on the cockpit shower that resulted in a fine spray in the fresh water system that was not visible from the outside of the stern. There is a separate shutoff for the cockpit shower near the pump on our boat.
Likes: Bryan9
Beneteau 323 Annapolis MD
Maybe the shower is left partially on and dripping?
Jul 18, 2013
2
Thanks for all the comments
It is unfortunatly not just the shower head - we have several years forgot to prepare that for the winter which as lead to a freze cracking - also this year. I have tried to leave the shover head haning out - and the water is still comming. I think I need to check the connection between the shower hose and hose from the water pump. This connection is some where in the space behind det starboard cockpit locker. HAs anybody tried to open that "room"
