Wall Fabric Alternatives?
SteveB
Hunter 34 Venice, FL
Time to replace the fixed windows. Sneaky leak rotted out bottom of portside cabinets (see pic). Will follow Allan Hadad's and Rich Bryers good directions on window replacement. Any ideas on alternatives to the old gray fabric sidewall covers? Jerry Koto's tongue in groove siding looks good in the V-berth, but this will get covered a lot by rebuilt cabinets. Any space age material that is pretty, easily maintained and makes her point higher?IMG_6006.jpeg
Hunter 34 Herrington South, MD
The hardest part was trying to discover what to call it in a web search. I used sailrite hull blankets in a whitish grey. Very easy to install, just spray hull and blanket, wait a few minutes and then press on. Should clean well since its a synthetic material. Lots of colors.
SteveB
Thank you Mike and Whatfiero. I was not aware of the hull blanket material nor that truck bed liner came in white. I can use each in different sections of the boat. Much appreciated.
