In less then a week I'll be visiting a friends 32' Endeavor that has a U 5424 engine with wheel steering.
Last year when I visited the transmission was fairly reluctant to engage in reverse gear as simply moving the shift lever to reverse was often not enough and revving the engine would sometimes help it kick into reverse gear. I'm told that the transmission is still as dodgy or even worse then it was last year. As a guest who does not mind some dirt under his fingernails I'd like to try to help the owner with this problem.
Preliminary research leads me to believe that it is likely a planetary transmission box conveniently located under the cockpit.
Here are the steps I'm thinking of going through to diagnose this problem:
- check linkage from binnacle to the transmission lever, put some oil in shifter wire to ensure smooth operation
- check tranny for proper level of lubricating fluid (ATF or what?)
- inspect brake band to insure that it will open and close freely and easily
Any other suggestions as to what I might check or what could cause this symptom of the tranny not wanting to go into reverse easily?
Needless to say not having a dependable reverse gear could make some docking operations a bit dangerous.
Thanks in advance.
Thanks in advance.
