Traveler turning blocks
Jun 22, 2016
4
700
I'm looking for a couple of turning blocks that mount on the side of the cockpit that turn the traveler line 90 degrees to get to the cam cleat at the top of the cockpit rim. The deck plan diagram lists this part as "block, bullet lead, upright, p&s". The boat is a 1992 CP-22. Catalina Direct doesn't have the item. Harken doesn't have a replacement. Does anyone know where I can get these or a substitute?
Feb 21, 2013
3,371
Hunter 46 Point Richmond, CA
Welcome to the forum!!
I see you are looking for part labeled 20 in the deck plan below. Not sure what the block, bullet lead, upright, p&s is specifically. Are you looking for hardware shown in the diagram on the right? Do you have any Catalina Capri 22's where you sail you can inspect how their rigging is set up?
Jun 22, 2016
4
700
Thanks!
Not the block on the diagram on the right. It is mid cockpit on the coaming sides, opposite the mid cockpit traveler. The sheave is vertical, not a horizontal cheek block as in your diagram on the right. Thanks for the reply. The closest match I have found so far is a Schaefer 02-50.
Jun 22, 2016
4
700
Yes! I'm looking for original equipment, but that is the closest so far. I'm going to measure today to see how close it is to the desired size and to determine if it is a good substitute.
