transom reinforcement?
May 23, 2016
1,024
Catalina 22 #12502 BSC
I've asked this b4, but just getting around to it...
Switching from 4.5 hp merc 2 stroke, to 6 hp Tohatsu 4 stroke. Heavier motor, want to reinforce transom motor mount bracket with backing plate inside to distribute the load. Looking for something quik/eze, I see 304 SS plate 3/16 x 12 x 12 at Graingers for $67...adequate enough? (don't necessarily want to use plywood, epoxy it, etc.)
Thoughts?
Mar 20, 2015
3,095
C&C 30 Mk1 Winnipeg
FWIW: Our 87 had a 15hp mercury 2 stroke on it, with big stainless washers. It appeared ok when I switched to the lighter tohatsu 6hp 4 stroke. I will eventually reinforce it but I don't see it as a priority. I visually inspect it, like the rest of the boat, regularly.
Likes: rpludwig
May 24, 2004
7,131
CC 30 South Florida
Surprisingly that 4.5 Merc 2 strokes weighs 45 lbs, I thought it be much lighter. The Tohatsu 6 HP 4 stroke weighs 55 lbs. A difference of 10 lbs. is not going to be significant. You may add larger washers to the bolts in back of the transom.
Likes: rpludwig
Jul 13, 2015
896
Catalina 22 #2552 2252 Kennewick, WA
I went relatively simple-- inherited two sticks to support my Honda 4 stroke. Wasn't pleased with the lack of support and added the ply. No complaints and relatively inexpensive minus the epoxy bath and marine ply:
Apr 11, 2017
571
Catalina C22 Solomon's Island, MD
Man -- that's some great access compared to the post 86' boats. To get back to that area in mine, it's like going headfirst into a coal mine. Looks good-
Likes: ShotgunSlim
May 23, 2016
1,024
It is great access (for gas fumes too, LOL)
Well, after all the great input on transom reinforcement, I'm rolling the dice with some big a$$ SS fender washers, lock nutz and some 4200....will report back if the transom falls off...hey, it's just a boat...
Cheers, hope y'all are on the water! & Happy MM Day, Semper Fi!
