Ahoy Aldi
It's a piece O'Cake to adjust, just hard to explain. Here goes,When you remove the cover plate you will see the Reversing Gear Case Assembly. The forward end of it is a large metal drum, which is the reversing gear casing. Set into the drum on the aft end are the clutch disks with pressure plate, and extending aft from them are three curved pressure plate fingers, they rest on a tapered metal cone. When you move the transmission linkage you will see it move the tapered metal cone, which slides back and forth on the drive shaft. Shifting into forward pulls the tapered metal cone aft spreading the three pressure plate fingers apart, this applies pressure on the clutch disks (due to cams at thier forward ends). The action of the curved fingers slipping into the grove on the tapered metal cone is what gives forward gear the "detente" feeling. When forward is engaged the engine crankshaft, gear casing, clutch, tail shaft and propeller shaft are all locked and rotate together as a single unit. So the prop rotates as fast as the engine turns. FORWARD ADJUSTMENT: Make sure the transmission is in neutral (easy to rotate the prop shaft). Moyer Marine recommends disconnecting the shifter linkage at this point but I did not find that necessary. Remove the cover plate and expose the reversing gear assembly. The three curved pressure plate fingers are attached at the forward end to a cast metal collar (the pressure plate). Rotate the pressure plate until the hex head metal retaining pin is facing up, it is half way between two of the curved fingers. The retaining pin looks like a small hex head bolt with a slot in the head. The bottom end of that bolt goes thru the pressure plate and extends into a slotted adjusting collar (staked collar). IMPORTANT: Mark the original position of the adjustment collar with a drop of paint before moving it because if you lose track of its position it can be time consuming to find the right notch again. Loosen the retaining pin until you can turn the adjusting collar. Make only small adjustments, they make big differences, adjust it one notch at a time. When I first tried this adjustment the collar seemed stuck, and gave way suddenly spinning several notches, I couldn't tell how many so it took alot of trial and error before I got it adjusted correctly. Turn the ajusting collar one slot (notch) clockwise. Clockwise rotation tightens the clutch. If you turn it too far clockwise the shifter lever will require excessive force to put it in forward. Several people have reported that on thier boat the difference between the clutch not slipping and very hard shifting was only one notch. Carefully retighten the retaining pin, making sure that it goes into a slot on the adjusting collar and GENTLY retighten it, it has a lock washer to keep it snug. People have been known to strip the threads or break the cast iron pressure plate where the retaining pin goes through it by over tightening this retaining pin. If you screwed up and the threads get stripped, it is possible to drill and tap a new hole in one of the other thickened sections of the pressure plate, each are 1/3 of the way around the plate. Adjust the shifter linkage if necessary for the neutral position. Test the linkage several times to shift in and out of forward, you want to feel the detente, but the shifting should not be unusually difficult. Reposition the cover plate to keep the oil in the transmission, then start the engine and test the prop for slippage. If it still slips, adjust the adjusting collar another notch and try it again. It usually doesn't take much to get it back into adjustment. Your problem is not slippage but to much pressure so I assume you get the idea of backing off the ring.Fair WindsCap'n Dave
