How about the easiest place? Any reasonably flat, level place in the hull below the waterline will work..Sand the mounting spot and clean it with acetone then stick the transducer down with a blob of epoxy glue..No air bubbles under the transducer. "Regular speed" epoxy works better than the 5 minute stuff...
