Air Shocks and more
Denise: We have had our Catalina 22 for 25 years, so we have pulled it out of the water and onto the trailer many times. I think that we have it just about figured out. I don't know much about Hunters though. When you say that you had trouble getting your boat back onto the trailer, was it side-to- side, or front-to-back? I added a guide to ours made from plumbing plastic pipe, to help get it to the right side-to-side position many years ago, and that really helped with getting the boat back onto the trailer. We sail in the Chesapeake, and you can't see below the surface of the water more than a few inches. To help with the front-to-back, I usually have my wife or one of my sons stand right on the stern, which helps kick the bow up and make it easier to winch onto the trailer. On the subject of modifying your van, I suggest that you get more advice, or question your mechanic a little further. We currently use my wife's GMC Surban to tow our boat, but we always used GM station wagons before that. We had Air Shocks on the station wagons, and they did the job. When we had the trailer on the boat, we added some air, and the back of the car came right up, and everything was nice and straight. When you change the springs, your van will ride rough all the time, except when you are pulling the trailer. Since you won't be pulling the trailer 99.9% of the time, it doesn't make sense to me to change the springs and ruin the ride of your van. As I said, with air shocks, you just have to add a little air when you are pulling the trailer. I'm trying to think why your mechanic said to change the springs, and the only thought that I have is that the springs will last for the rest of the life of your van, and airshocks will probably last only about 7 to 10 years. I still think airshocks are better, but get additional opinions on this issue. On your comment about extending the reciever. This will greatly increase the load on the rear of your van. Were you planning on doing this just to recover the boat from the water? If yes, then that will probably be OK, but I don't recommend that you trailer your boat with the extension plugged into the reciever. This actually scares me. The increase in stress that you would be putting onto your reciever would be very great. I'm a Mechanical Engineer, and I worry about things all the time, and I just don't want you to have your van break or your boat or trailer get damaged. Skip gave you good advice about learning. I'm still learning plenty after 25 years of sailing, and just learned something from a different forum last Friday that I had been wondering about for 20 years.One more thing, you should write some notes on pulling your boat from the water. I did this a few years ago and it has been very helpful. Things like how far you backed into the water, (like "the rear wheels were almost in the water"), which ramp you used, how far you pulled the boat relative to the bow stop, etc. Since you don't do this every day, you will forget some of these details. If you have notes that you read just before you pull your boat out of the water, one little detail could really help. I also have many lists that have really helped me with the trailering aspects of using our boat. If you forget just one little piece of hardware, it could really ruin your day, or cost a bunch of money, so we have lists for taking our boat to the water in the spring, and lists for pulling it out in the fall. There are also lists of tools to keep on the boat, and checklists before leaving the boat when it is in the slip, and lists of things to do over the winter to have the boat ready in the spring. I wish you the best. We enjoy our boat more and more every year, and I wish the same for you. Aldo
