New Brake lines
Hello Dan, I had to replace the flexible hose on my H23 trailer about a year ago, after the original hose sprung a leak. Unfortunately, I had a hard time finding anyone who would put together a 6' length of flexible brake hose; Most automotive brake shops won't touch it (insurance reasons), Auto parts stores aren't much help unless you have part numbers, and there weren't any hydraulic parts manufacturers in my area (These are the people who would custom-build a high-pressure hose). What I ended up doing was going to the auto parts store to find three short sections of brake hose (approx. 1 foot each) with standard brake couplers on either end, and two peices of standard brake line (about 2 feet each), and coupling all this together in the following order:Master cylinder - Flexible hose - Brake line - Hose - Brake line - Hose - fixed trailer brake line on trailer. With the tongue extended, the line is about 3" too long, but does not drag on the ground at all. When the toungue is shortened, I have to remember to lift up on the center section of hose to prevent crimping, but it folds itself into an upside-down "V" shape that I attach to my trailer winch with a short bungee cord. So far, I haven't had any problems with this arrangement; Unfortunately, I didn't write down all the part numbers so I'm going to have to play "search the shelves" at my local auto parts store again when this rig wears out. I'll post pictures if you're interested...--Jon BastienH23 '2 Sheets to the Wind'
