Convenience
Alan,Your point on a slight performance advantage gained by not having excess weight (topping lift, Windex?) aloft is well-made. I doubt that the extra 12 ounces of line makes that big a difference though- the added windage is probably the bigger issue.But for us single-handers, the 'clamp the halyard d-shackle to the stern end of the boom after lowering the main' idea is inconvenient. I haven't found an easy way to single-handedly drive the 170, reach all the way forward to the main's headboard to unclamp the d-shackle and lead it aft, all while keeping the boat from rounding up. A tiller tamer would fix this but the 170 is still such a free spirit, that I'm not sold 100% on the idea that a tamer would keep the boat tracking true while I went forward to get the halyard. This dinghy is so responsive to weight shifts. Granted stopping dead in the water and, traffic permitting, allowing the boat to wander slightly while performing a halyard-to-boom operation would be a solution, when done with awareness of where other nearby craft are. Moreover the topping lift is easily reachable during sail-lowering (whether the topping lift has just been left to hang loose, still cleated at the tail of the boom, or tied-off down the outside of an upper shroud), obviating the need for reaching all the way forward and up to the headboard.Mike G.
