Ran mine aft...
Hi Mike, When I bought my H23, it had the main halyard run aft (but not the jib). I ran the jib halyard aft, but left the boom lines in place. I don't tend to spend a lot of time adjusting my outhaul or topping lift much; If I'm singlehanding, I'll leave a little extra line out on the topping lift (lets the boom hang lower), so I don't have to adjust it when I raise the main. As for the winch, I haven't moved it from its place on the mast because it is instrumental to my mast raising/lowering method. I haven't really needed a winch for my halyards, since I fixed all the broken sheaves in the mast ;o). (That reminds me - You may need to purchase an extra sheave to go into the base of the mast for the jib halyard when you re-route it.) If I do need to crank on a halyard, I can always use the jib winches...Also, the way the lines were run aft on my boat was very simple- Not even turning blocks or deck organizers, just a few "bull's eye" fairleads and some cam cleats. I can send you pictures if you like...--Jon BastienH23 '2 Sheets to the Wind'
