What happens if you don't go sailing enough?
After raising the mast the (new this year) topping lift cable somehow goes over the top to the windex arm. Causing you to lower the mast and try again.
After raising the mast again and attempt the connect the forward lower stays you notice the rear and main stays are looking different under the boots.
After inspection you realize you've bent not 1 but 3 tee-bolts.
It was a nice trip after that though.......
