Terminating Tank Sender Unit
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Hey Maine Sail,
I hope your summer is going well and you are getting some sailing in! :D
Currently my sender unit on my Catalina 310 is not working. I have ordered the Moeller mechanical sender unit with the conversion capsule. My current sender unit is terminated with ring terminals. The conversion capsule is terminated with spade style quick disconnects. So either way I am cutting of one side to make these match. My first thought is to cut of the spades and put on ring terminals and connect through a Blue Sea System's 20 A terminal block.
Just wanted to check and see if you had a preferred way to make these connections.
Thanks and fair winds,
Jesse
