Ok my bad. I read this and concluded you had running back stays.What should the tension on running rigging.
Running rigging should always be tensioned to about 15% of it's breaking strength. Most people underestimate this and leave it WAY too loose. Because wire stretches at a uniform rate based on its diameter, there is any easy way to set this up without a Loos gauge. It's called the folding rule method.
This guide from Selden explains it, and how to tune various rigs. A copy should be on every boat owners computer or tablet.
https://www.dropbox.com/s/ilab8s9lqta2mjv/Selden Hints and Advice.pdf
Did you mean standing rigging? Running rigging is the halyards. Those, unless you are racing, you leave them alone. Why work?What should the tension on running rigging. Cat 30 tall mast.
