Hey all,
My VHF radio installation is the project that just won't end. I've installed an antenna at the top of the mast, fished coax through the mast, drilled and installed a through-deck fitting for the coax, and mounted the VHF radio next to the companionway tucked in the quarter berth.
The last step (I pray) is to run power to to the radio. But, I can't make heads or tails of the wiring on my switch panel. Can anyone provide any guidance as to how I tap into the panel to power the VHF radio? The labels on the switch panel are... interesting. There is definitely no bilge on the boat, nor an AM/FM radio. But otherwise, the top three switches all work as advertised. (I think they meant to label anchor light as steaming light, but I digress.)
So, how in tarnation do I run power from this switch to the VFH radio?
Here's the back of the switch, and the front.
Much appreciate any guidance.
- Andre
- Andre
