Dear friends,
My Beneteau 311 has lost its swing keel. The factory doesn't have a replacement nor actual drawings.
Noticed the C22 swing keel is similar in dimensions and weight so that could be a repair option. Have found the drawing below so I can build a template but need to know how thick the C22 swing keel is at its thickest part.
If it works I'll attempt to find a C22 keel from someone.
If you are wondering how this would be possible, have attached a picture when the boat still had the swing keel part.
Thank you so much.
Tony
Thank you so much.
Tony
