My controls are reversed after the prior owner had some transmission work done.
SV_IdleHour . Jan 3, 2020 53 Hunter 27 Hoboken Feb 2, 2020 #1 My controls are reversed after the prior owner had some transmission work done.
sailermaned . Nov 26, 2014 51 HUNTER h31 Northport L.I. Feb 2, 2020 #2 Sounds like shifter tab is installed backwards, I would look to change that before reversing prop. Forward and reverse may not have same gear ratio. Likes: Captain Larry-DH and SV_IdleHour
SV_IdleHour . Jan 3, 2020 53 Hunter 27 Hoboken Feb 2, 2020 #3 sailermaned said: Sounds like shifter tab is installed backwards, I would look to change that before reversing prop. Forward and reverse may not have same gear ratio. Click to expand Hadn’t thought about that—thanks! I’ll take a look
Captain Larry-DH . Jun 14, 2010 2,350 Robertson & Caine 2017 Leopard 40 CT Feb 17, 2020 #4 sailermaned said: Sounds like shifter tab is installed backwards, I would look to change that before reversing prop. Forward and reverse may not have same gear ratio. Click to expand Bingo Unless the transmission was changed that‘s got to be the issue Likes: SV_IdleHour
