You mention " > Switch Panel > Fuse Block >". Most of the commercial switch panels have a fuse or breaker associated with each switch. I'm assuming you might not be using one of those if going with the Blue Seas fuse block you showed in another post. If using it and making your own panel with switches on it or at various locations I would...
1. Battery
2. Use the double fuse that mounts on the battery post.
3. One fuse sized for the wire running to the outboard.
4. Another fuse sized for the wire running to the fuse block.
5. Don't need to have a positive buss just a wire to the fuse block sized to carry the load of all the circuits and protected with the right size fuse at the battery post.
6. Fuse block with fuses sized for the wires running to the switches that control individual loads.
http://1fatgmc.com/boat/end-1/endeavour-elect/page-3.html
I use two of those fuse blocks on the Endeavour, one has 6 fuses and the other 10 fuses and there is a large on/off switch on the wire from the battery to the fuse blocks so that the loads can be disconnected at once if needed. Also wired the Mac with one of those Blue Seas fuse blocks.
I made my own switch panels as I found the commercial ones two confining and wanted to run the fuse blocks vs. having the fuses with each switch. Just my choice.
One fuse in the fuse block might in some cases go to more than one switch if the loads are light. I might have say a 10 amp fuse and from it go to a terminal strip with jumpers and from the terminal to 3 different toggle switches. If all the wires are #14 and the combined load with all on is less than 10 amps the fuse won't blow and the fuse will more than protect any of the wires. Saying that most of my fuses protect a single wire going to one switch and one load.
Main point is having fuses on any of the circuits sized for the wires following them as has been mentioned by others above and there are a number of ways that you could also use the fuse blocks in conjunction with switches that have fuses with them but that would take a lot more writing than I'm welling to put in at this point. Are you going to make switch panels or buy them and if so ones with or without associated fuses with each switch?
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Wyoming, Canada, Florida, Bahamas
