ST50 Speed Log Temperature Function
Michael McCann
Bill; A friend's ST50, and mine are approximately the same age (new in 1992/1993). His temperature reading is 28 degrees, while mine reads 51 degrees. Same day same water. Could this be in the transducer, or the instrument? Thank you for a great forum. There have been some great posts. Mike
Bill Boudreau
Temperature Test
There is no calibration adjustment for the Temperature in the ST50 Speed. To see if there is a fault with the transducer assembly, do following test; Disconnect the transducer cable from the display head and locate pins 1 and 2. You do this by facing the plug end of the instrument cable with the reference notch at six o'clock position, Pin 1 is at 7 o'clock and pin 2 is at 10 o'clock position. With the instrument powered on, place a 10Kohm resistor between Pin 1 and Pin 2. The display should give a reading of 25 degrees Centigrade. If this is the case then we can assume the instrument is functioning correctly and the temperature error is due to a faulty transducer or cabling.
Don S
Same Problem Same Year
I am having the same problem. My boat was bought new in 1993. I do have a very balky knot meter though. I need to clean the paddle wheel every week if I want to have a knot meter. Most times I just don't bother. When I clean the wheel, the temperature still reads 19 deg F
Michael McCann
Don S. (ST50 Temp)
Don; If the weather allows, I will do the test on mine this week end, and let you know. I didn't say, but the water temp is getting colder on mine (it is now reading 49 degrees F), however the water could be that cold at this time. I will not be able to check my friend's out, as his boat is in Seattle's Lake Union at this time. Mike
Bradley Cavedo
Mine doesn't work
It used to work great and give good water temps. Then there was a lightning strike about six boats over in the marina and the temp has been wrong ever since, by 20 degrees on average. The Raytheon people said the only fix is a new transducer/paddle wheel. Tooo expensive, particularly when the speed works fine.
