G
GARY ELSTON
BRION,BOAT IS '86 STARWIND 223. REPLACED THE PORT UPPER SHROUD AFTER INSPECTIING (THANKS FOR YOUR VIDEO) PROBLEM IS I'VE BEEN TOLD THAT THE SHROUDS SHOULD MOVE EASILY THROUGH THE ENDS OF THE SPREADERS BUT THE SLOT IN THE SPREADER OUTER END IS WAY TOO SMALL FOR THE SHROUD (1/8"). THE SHROUDS ARE KEPT IN PLACE BY A SMALL PLATE ATTACHED TO THE ENDS WITH TWO SCREWS. PREVIOUS OWNER HAD THEM TIGHTENED DOWN SO SHROUDS COULD NOT MOVE, IF I LEAVE THEM LOOSE ENOUGH TO ALLOW MOVEMENT I RISK THEMWORKING OUT. WHAT DO YOU ADVISE?THANKS, GARY
